Horizontally flip TV image
(Topic created: 07-06-2024 12:38 PM)
rkl1
LED and OLED TVs
Is it possible to flip the image horizontally on all Samsung TVs or just certain models?
I have a Samsung UN43TU700DF, and I have navigated through the software but find that the HV Flip is greyed out. Is it possible to activate it, or an I just out of luck?
I'll buy a new Samsung if you will tell me which 32" to 50 inch TVs will allow me to flip the HV setting.
Thank you
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Yes, most Samsung TVs will have the option to flip the image. It will be just based on what input it is on. I would recommend trying all inputs and picture settings to get this to work. Also, make sure that your TV is up-to-date. If none of this helps, then try a factory reset on the TV also.  If none of this helps. Please call in directly at
1 (800) 726-7864 and ask for our remote management team.
1 Reply
Samsung_Moderator
LED and OLED TVs
