Internet Connection
(Topic created: 07-28-2024 08:52 AM)
Members_adRzLZ7
LED and OLED TVs
Our TV is about a year old.  Relatively recently we have encountered an issue with the TV connecting to the internet when we turn it on.  The only way we have found to get the connection is to unplug the TV and plug it back in, then it powers up and connects as normal with the internet.  So now every time we turn it on, we don't get a connection and have to unplug the TV then plug it back in and turn it on, then it works properly.  We have tried a number of things and most of them we have tried repeatedly hoping something would work, so far no luck.  Any ideas?  Thank you.
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
Have you power cycled your router and deleted the connection on the TV and created it again after the router power cycle?
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
LongHiker
Galactic Samsung Care Ambassador
LED and OLED TVs
@Members_adRzLZ7 Is it connecting via Wifi? If so, it could be an issue with Wifi signal strength at the TV location.
rdk25
LED and OLED TVs
Thanks for the idea. We are getting a strong signal. We checked to be sure. Once we unplug and plug it back in, it comes on like there was never an issue.
bill-e
LED and OLED TVs
Bill
rdk25
LED and OLED TVs
I'm pretty sure we haven't. We will give that a try. Thanks for the idea.
Jeffonorge61
Cosmic Ray
LED and OLED TVs
For me, I would reboot by holding the power button on the remote until the set turns off automatically and turn back on by itself, then half a minute or so later the set automatically would prompt on the screen, you are signed in to your email address . (UN32N5300)
