Need a Sound Bar for my Samsung DU7200
(Topic created: 08-12-2024 02:51 PM)
HEJ
LED and OLED TVs
I recently bought at Best Buy a 43" Samsung smart TV, DU7200, Crystal UHD. The picture is great; the audio sucks. I need recommendations for a Sound Bar that will remove the "mushy" audio that sounds tinny. I don't want to spend a thousand dollars for a $330 smart TV. Any recommendations. I need the sound bar to rest underneath the TV on the mantel. Thanks for any and all recommendations.
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
I have this and it works great
https://www.bestbuy.com/site/sku/6505155.p?skuId=6505155
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
LED and OLED TVs
HEJ
LED and OLED TVs
Thanks for your recommendation. Much appreciated.
HEJ
LED and OLED TVs
Thanks for the suggestion. Much appreciated. I will go ahead with your recommendation.
Rss0213
LED and OLED TVs
What are the connection options on this tv? I have the 65” DU 7200D and mine has no optical output (or at least I don’t see it). And when I look at the connection settings in the menu I don’t see anything but HDMI options. So disappointed. I thought all TVs this new had an optical output option for audio.
