LH70BEC-H - any options for external control? (RS232 via USB adapter, etc)
(Topic created: 05-21-2024 07:20 AM)
jcaumb
LED and OLED TVs
We have an LH70BEC-H display in a conference room and the display it replaced had been controlled by a Crestron system which sent commands via RS232 serial.  I know there's no serial port on this display, but there is USB.
Are there official/compatible USB adapters to send serial commands to this display? Or are there any other alternate methods for control via external sources?
Alternately, is there a setting or service menu that can be accessed to enable power on signal detection?
I know IR blaster is one solution, but power on signal detect would be helpful, and serial, USB, or other commands would be ideal.
Thanks!
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Unfortunately, we do not have anything official for this. There may be some 3rd party devices that can make this work however we can not guarantee compatibility with them.
1 Reply
Samsung_Moderator
LED and OLED TVs
