UN50HU8550FXZA problem with tv fan and tv may overheat
(Topic created: 05-27-2024 04:15 AM)
Duxsix
LED and OLED TVs
TV was purchased in 2014.  Over the past two months I get a message when tv starts up (about 50% of the time this happens). Message says "problem with tv fan and tv may overheat. TV will shutdown shortly to protect the TV".    However the tv does not ever shutdown remotely. I can shut it down and restart after 10-20 minutes and message goes away. Any ideas?
realaud
Honored Contributor
LED and OLED TVs
It's a 10 year old TV, it will have problems.  Maybe it hasn't been shutting down automatically because it didn't actually reach the temperature threshold to do so.  In any case, you should see about getting the fan replaced by a competent repair outfit. Although it might be better to see about getting a new set with the advances in technology.
Please mark any response that helped you as your solution.
realaud
Honored Contributor
LED and OLED TVs
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
It's sounds like it's on board sensor is telling it it's getting too hot.  Unplug the TV for 1 minute to reset it and see if it was a software glitch and goes away but most likely the TV needs service.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
LongHiker
Galactic Samsung Care Ambassador
LED and OLED TVs
@Duxsix Over 10 years it could be that significant dust/dirt has built up internally. The dust/dirt accumulation is preventing proper cooling.
