Pop up notification every 2 hours or so on my QN90B
(Topic created: 2 weeks ago)
EsQueue
Cosmic Ray
LED and OLED TVs
For the past 2 days, I've been getting an EXTREMELY annoying popup notification with small ding sound. This pops up about every 2 hours and disappears in 5 seconds. Impossible and just plain silly to not be able to read it. It does say something about thanks for being a customer and that smart hub collects data in some kind of way and that you can mess with settings in settings. I have never been able to read it as it leaves so fast. I just disconnected it from my network prior to posting this. Anyone knows what this is and most importantly, how to stop it?
I only hope that disconnecting it from my network will stop these messages but only thing I can find under privacy settings want me to agree to a bunch of check marks. I clicked none of them as I do not agree with their TOS for something that I rarely use. This TV is strictly as a monitor and have no antenna connected. I could completely disable smart hub as I may just have by disconnecting the network connection.
UPDATE EDIT:
Taking the TV offline seemed to have fixed the issue but the loss of IP remote control via watch and home assistance is an annoying too. My plan is to Block the TV's mac address from any WAN (Wide Area Network) access via my router. I'll put it back on the network so that my home assistance setup still has access to it so I'll still have my remote control features but the TV and Samsung has no access to and can't make changes to my purchased and owned property.
The TV is used as a monitor like I said so a dumb tv will be fine if I can't get it to work how I mentioned. I'll update if anyone even cares about that route.
UPDATE 2: I have since reconnected my TV back to the network and instantly saw the warning again. I then blocked WAN access of the TV via my router but it is connected to my LAN only.
I then disconnected my phone offline to test and still have access to my Home Assistant features to the TV online as that is via a encrypted DDNS running through my own micro PC setup along with every other former cloud device I own. All controlled by me. Now Samsung can't break what they can't connect to.
JUMP TO SOLUTION
userdooJ0dFjR2
LED and OLED TVs
It would be nice if a multi billion dollar corporation would pay attention to forums like this, but alas, they simply do not GAF. Thanks Samsung.
phil30087
LED and OLED TVs
Is anyone from Samsung going to fix this or am I going elsewhere in future - clearly this is a Samsung issue and there is only so much patience that I will afford them right now
Ek2222222
LED and OLED TVs
Same problem here, samsung needs to put up a new update to remove this or i'm done with all my samsung products
JS111
LED and OLED TVs
Just got off a text thread with a Samsung rep. After telling them all about this and describing the message, he told me that it was inserted into a recent update to "comply with evolving privacy regulations". When I asked why it kept appearing, and why I couldn't turn it off, his response was "I am extremely sorry for the inconvenience caused to you, but that cannot be turned off, we will take this as feedback". For me, that translates to "Sucks to be you, you shouldn't have bought a Samsung TV". Lesson learned, I guess.
Shyko710
LED and OLED TVs
Even if you agree to everything it still pops up
killroy6767
LED and OLED TVs
This is unbelievable.  Are they watching me through my tv.  If I am constantly reminded of my privacy being violated.  Samsung,  you have just lost and customer.  Plenty of other great companies to choose from.  4 days of this message!!!
CV5
LED and OLED TVs
Check out what the message says. It directs you to the policy statement that describes what information is collected.
They aren't "watching" you.
DanKPalumbo
LED and OLED TVs
Does anyone know if Samsung is addressing this?
minpins4ny
LED and OLED TVs
I signed out of my Samsung account on my Samsung smart tv and the pop up stopped. I did this after going into settings/ security/ privacy and opting out of everything ( meaning do not check anything) click OK. Log out of your Samsung account through settings. Hope this helps
madatmyTV
Cosmic Ray
LED and OLED TVs
This worked for me, three days no popupā€™s
