S95C OLED - USB Playback?
(Topic created: 05-25-2024 05:56 AM)
userr2JJH1m87u
LED and OLED TVs
Hi everyone,
I just got my new S95C OLED. I have a question about the USB ports on the connect box. If I plug in a USB flash drive will I be able to play a selection of files or will I only be able to play one file?
How does USB playback work?
I would like to put some documentaries (in different directories) on a flash drive and be able to select which I would like to play.
Cheers!
Robin621k
Honored Contributor
LED and OLED TVs
After you insert the drive into the USB port, press the source button. There, you should see your drive, click on it, and select the file you want to play. You will have to click on each file to play. It doesn't have autoplay to the best of my Knowledge
aubriella
LED and OLED TVs
I do not know but When I find out I will tell u
Robin621k
Honored Contributor
LED and OLED TVs
userr2JJH1m87u
LED and OLED TVs
Thanks!
But, can you use directories?
Cheers 🙂
