Samsung SMART TV UA55K6300 "ON TIMER" feature wont let me choose USB or TV source option.
(Topic created: 11-12-2024 01:33 AM)
tomatolollipop
LED and OLED TVs
We have a samsung smart full hd tv (UA55K6300), and I want to utilise the "On timer" feature which allows me to setup a specific time when it turns on automatically. As the Title says, there are source options to choose when setting this up, but unfortunately it won't let met choose on either TV or USB as its source. HDMI 1/2/3, DVI, AV and COMPONENTS can be chosen as source.
I want to set it up that when every time this feature is used, it automatically goes to the input source TV (coaxial cable)/USB not in HDMI.
Can someone please tell me how I can get the built-in "On Timer" feature/function to automatically recognize my TV's input Source as being TV/USB?  Thanks in advance for any assistance.
The software/firmware version is also updated to latest version: T-HKMFKUABC-1260.1
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Unfortunately after looking at this further this option is not available for coaxial/USB this can only be used for HDMI, DVI, AV and COMPONENTS.
1 Reply
Samsung_Moderator
LED and OLED TVs
