Samsung TV remote replacement
(Topic created: 10-30-2024 09:49 PM)
Robinpockets0724
LED and OLED TVs
What TV do I have and what remote app works with it the factory remote got something liquid in it and shorted that side out but the key board still work any one got one of them laying around they aren't using [tv]UN55D7000
SOFTWARE VERSION: T-GAPAKUC-1020.1 , BT-Q what remote app works???
CAN SOME ONE HELP ME WITH THIS MY EMAIL IS 7deank24@gmail.com
JollyCello
Galaxy
LED and OLED TVs
@Robinpockets0724 you can basically use any Samsung remote to work the basic functions of your TV. $30 for a new remote on https://samsungparts.com/collections/remote-controls
JollyCello
Galaxy
LED and OLED TVs
Robinpockets0724
LED and OLED TVs
I haven't been able to get anything to link I can't even get my samsung phone to link to the **bleep** thing
user_ams007
Planetary Samsung Care Ambassador
LED and OLED TVs
If you have a spare remote control available, point the remote at the TV and press and hold the Return and Play/Pause buttons simultaneously for at least 3 seconds. The remote control at the TV should pair with your tv , You can also try using the Samsung SmartThings app to control your tv with your phone ,open smartthings, and then select the lab's feature and select the Bluetooth keyboard or universal keyboard
