Tv bluetooth help
(Topic created: 04-20-2021 04:13 PM)
userpZOa4FlBop
LED and OLED TVs
I am trying to connect my tv to my computer through bluetooth. It has an hdmi port but I want to use bluetooth. It's model code is UN46ES6100 which I think means it's a 6100 series tv. I don't see any option for bluetooth in the menu.
Not applicable
LED and OLED TVs
You may be able to find a third party BT Wireless Display to HDMI adapter. Samsung does not make such a device.
Not applicable
LED and OLED TVs
Sorry, the UN46ES6100 does not support a bluetooth connection to your PC.
userpZOa4FlBop
LED and OLED TVs
Is there something I can get that will allow bluetooth on my tv? Something I can attach using the hdmi port?
Not applicable
LED and OLED TVs
userpZOa4FlBop
LED and OLED TVs
Ok, thank you for your help
Not applicable
LED and OLED TVs
You are most welcome.
