- Mute
a week ago in
LED and OLED TVsHow can I add channels without running a scan? or even just manually tune to a channel not in the scan list?
Not all the transmitters are in the same direction so the antenna has to be pointed different for different channels. It is not feasible to rescan every time I change channels. It would be fine if you could scan and only add new channels, but instead it deletes all previous channels every scan.
Omni-directional antenna won't work, signal isn't strong enough.
- Mute
Sunday in
LED and OLED TVsNo replies so I guess there's no way, so I have to ask why Samsung removed this option? Do they not have the sense to know that there might be cases where not every channel gets picked up in a single scan?
