smart remote with a microphone
(Topic created: 02-06-2025 10:41 AM)
Darrell2
LED and OLED TVs
UN50DU6900FXZA  S/N <hidden> what smart remote with a microphone will work with this model
<hidden>
Samsung_Moderator
LED and OLED TVs
Hey, Darrell. We appreciate your inquiry about your Crystal UHD TV. I pulled up this model and saw that it supports Smart Remote voice commands, which is called Voice Assistant. The Smart Remote that is compatible with this model is the Samsung Bn5901388a / TM2240A 2023 IR TV Remote Control. Unfortunately, I don't see the model on our site. However, you may be able to find the remote from a 3rd party site.
Ensure the remote is paired correctly. You can pair it by holding the Return and Play/Pause buttons simultaneously until the TV recognizes it. Let us know if you need further assistance!
LED and OLED TVs
Your TV does not support voice remote control.
Samsung_Moderator
LED and OLED TVs
Darrell2
LED and OLED TVs
I found one that works the  Samsung BRN59-01312A/RMCSPRIBP1
