Help finding size of vesa mount screws for Samsung T350 Series 22-Inch (LF22T350FHNXZA)
(Topic created: 11-12-2023 04:12 PM)
John Denis
Monitors and Memory
Greetings! I'm trying to find the size of vesa mount screws for Samsung T350 Series 22-Inch (LF22T350FHNXZA). I can't seem to find the info anywhere I've searched. Any help will be greatly appreciated.
GaryB82
Galactic Samsung Care Ambassador
Monitors and Memory
The manual says 4mm you can see also on this site https://www.manua.ls/samsung/f22t350fhn/manual?p=12
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
1 Reply
GaryB82
Monitors and Memory
