- Mute
3 weeks ago in
Monitors and MemoryJust set up my new OLED G9 49" on my PC with a Geforce RTX 2060, encountered two issues immediately:
- Display Port does not work - it registers a signal but black screen
- Jog switch does not appear to be working correctly, especially left (source selection) and up (functional menus). As a result, I can't access the monitor's settings. I've tried power cycling.
Any advice would be appreciated before I initiate a return.
Solved! Go to Solution.
- Mute
3 weeks ago in
Monitors and MemorySorry to hear your having this issue if the buttons won't function correctly and the display port won't display a picture I would suggest contacting support to see what they may be able to do before starting the return process
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
- Mute
3 weeks ago in
