How can I get a replacement S Pen for a Note 20 5G?
(Topic created: 06-25-2021 10:04 PM)
GingerQueen
Note20
Ok so I bought my Note20 5G from a friend's brother right.  Like just 2 days ago.. Anyway, he misplaced the S Pen and I was wondering  how to go about getting another one..  So if someone could point me in the right direction  that would be awesome....
Thanks in advance..
Not applicable
Note20
You can buy a replacement through Amazon or the Samsung Shop app
DeeTrust
Note20
Amazon
GingerQueen
Note20
It will still work with the air commands?
DeeTrust
Note20
Yes it will, I just bought 1 recently and I've had no issues. Air commands work just fine20210626_014916_224.jpg
lilamber2021
Note20
Order S pens on Amazon . Just type Note 20 5G S Pen. Hope this helps you 😁
Shorty685Crystal
Note20
Try Home Depo
Not applicable
Note20
HarleyAnnieTime
Note20
Couple months ago, I ordered my FIRST REPLACEMENT S-pen from Amazon but you can get em plenty places, no trouble. I'd just add a few things to consider. Since most of these products are not official Samsung versions, BE SPECIFIC if that's important for you. And the same goes for Bluetooth capability. That said, I already need a REPLACEMENT for my REPLACEMENT pen.
SAMSUNG, Y'ALL SERIOUSLY NEED TO UPGRADE THE S-PEN LOCATE FEATURES TO 'USEFUL LEVEL'.
At bare minimum, a Sound Alert but I don't believe you can't help me find the $35+ ítem that you've neglected to either tether to the $1000+ phone or even seat it properly in the custom port.
It's almost as if you DESIGNED LOSS into the S-pen.
So, did you?
