- Mute
ā12-13-2023 04:50 PM in
A Series & Other MobileSolved! Go to Solution.
- « Previous
- Next »
- Mute
ā03-28-2024 08:56 PM in
A Series & Other Mobile- Mark as New
- Mute
ā12-24-2023 10:13 PM in
A Series & Other Mobilei also have an a54 with this newfound problem, with the interesting caveat that it only affects my bluetooth earbuds but not my speaker (which is an anker, for those interested). i had already enabled dev settings and already tried the trick with audio codecs as part of my troubleshooting arsenal, all to no avail. i reset bluetooth/wifi settings (that didnt work), i updated my phone with the new security patch that dropped earlier today (which affected nothing), and tinkered with every single bluetooth tab in the dev options menu (and even a few unrelated specs for good measure, none of which made an ounce of difference). it is literally just an issue with the latest UI update, i have no other explanation. my earbuds work perfectly fine on any other bit of tech, just not this specific phone after this specific updateāand after stumbling onto this thread im relieved to find that this isnt just me. hopefully samsung finds a way to patch this up quickly.
- Mute
ā04-09-2024 06:51 AM in
A Series & Other MobileI turn off A2DP hardware too, now my Jlab working great with my Galaxy A54 5G
- Mute
2 weeks ago in
A Series & Other Mobilesame issue, no solution works
could samsung give us a fix?
- Mute
a week ago in
A Series & Other MobileThank you jwhman2002. You're our genius of the year ! Solution is excellent (finding Developer Mode on the A54 is tricky, but once there all is good 8-). Cheers !
- « Previous
- Next »
