JC85
- Mute
ā04-13-2024 04:19 PM (Last edited a month ago by SamsungJoJo ) in
A Series & Other MobileMy screen won't turn on/off using the power button. How do I fix this?
A13 is the phone
Charkatak
Honored Contributor
- Mute
ā04-13-2024 05:27 PM (Last edited ā04-13-2024 05:28 PM ) in
Was your phone turning screen on/off with power button before? You have to find out if your phone has a warranty. If it does, contact Samsung support.
RyanSr
Comet
- Mute
ā04-13-2024 06:46 PM in
It should respond when you double tap on the screen. You can also hold the power button down for 10-15 seconds or so which should force reboot the phone
