- Mute
08-24-2021
10:09 AM
(Last edited
11-20-2021
03:18 PM
by
Samsung_Stephan
I downloaded the app on my windows pc but when I want to start it, it crashes ;(
Solved! Go to Solution.
- Mute
11-18-2021 09:39 AM in
Projectors & Other TVsWe have escalated this to our specialists, in the meantime it is recommended to submit an error report through the Members app using the steps below:
Open Samsung members app -> log-in with Samsung account -> Explore -> press “+”sign -> Add frequency /issue description -> send
- Mute
08-24-2021 10:26 AM in
Projectors & Other TVs- Mark as New
- Mute
09-12-2021 07:36 AM in
Projectors & Other TVsI've got the same problem here. Have you maneged to fix it?
- Mute
10-22-2021 06:18 PM in
Projectors & Other TVsno dont know what to do ;(
- Mute
10-01-2021 04:36 PM in
Projectors & Other TVsSupport tells to wait for update(
ps: do you start it with admin rights?
- Mute
10-22-2021 06:19 PM in
Projectors & Other TVsYeah, I did but it still the same
- Mute
10-22-2021 01:18 AM (Last edited 10-22-2021 01:21 AM ) in
Projectors & Other TVsMe esta sucediendo lo mismo, al querer iniciar el programa de easy connection to screen en windows 11, se cierra la ventana constantemente, solucion por favor.
Gracias
- Mute
10-22-2021 06:20 PM in
Projectors & Other TVsAun no tengo solucion al problema, amigo ;(
- Mute
10-24-2021 02:58 AM in
Projectors & Other TVsNo funciona
- Mute
11-02-2021 12:28 PM in
Projectors & Other TVsHaving the same issue, it crashes instantly after opening the program.
![](/skins/images/98FDEB1C347D61F2FA4E850FD1AE5BF3/responsive_peak/images/icon_anonymous_message.png)
