Bluetooth not working on Frame TV
(Topic created: 09-09-2025 02:54 PM)
Hellofish1
QLED and The Frame TVs
I have a 2021 75โ€ Frame TV (QN75LS03AAFXZA) running firmware version 2230 where the Bluetooth is not working. I discovered this as I was trying to pair a couple new aftermarket remotes to the TV and noticed that it was only using IR and not Bluetooth. I then tried to pair a Samsung OEM remote and kept seeing the message โ€œNot Availableโ€ on screen. I finally tried pairing Bluetooth speakers through the sound output menu but it canโ€™t seem to find any devices.
After multiple soft and hard resets as well as a couple factory resets, I went into the hidden system menu to see if I could access any Bluetooth menus. In the debug report I see โ€œBT Throughputโ€: โ€œFailureโ€. I suspect this means I have an issue with my Bluetooth controller or firmware.
Does anybody have a fix for this? Thank you in advance.
Samsung_Moderator
Thank you for your question and Welcome to the Community, Hellofish1
The message โ€œBT Throughput: Failureโ€ on a Samsung TV typically refers to a Bluetooth transmission issue. It means the TV is unable to maintain a stable or sufficient data rate with a connected Bluetooth deviceโ€”such as headphones, soundbars, or controllers.
What It Means:
BT = Bluetooth
Throughput = The rate of successful data transmission
Failure = The TV couldnโ€™t establish or maintain a reliable connection
Common Causes:
Incompatible or unsupported Bluetooth device
Signal interference or physical obstructions
Outdated TV firmware
Internal Bluetooth module issues (rare)
Troubleshooting Steps:
Restart both the TV and the Bluetooth device.
Ensure the device is in pairing mode and close to the TV.
Remove previously paired devices from the TVโ€™s Bluetooth settings.
Check for firmware updates via Settings > Support > Software Update.
Try connecting a different Bluetooth device to test compatibility.
If the issue continues, we recommend visiting the official Samsung Support site for further assistance:
https://www.samsung.com/us/support/
Please let us know if this of any help to you!
Samsung_Moderator
What It Means:
BT = Bluetooth
Common Causes:
amaderog
How do you get to the hidden system menu to get the debug report?
