How do i connect antenna to Qled tv? Coaxial
(Topic created: 01-12-2025 02:41 PM)
Members_PMetu8z
QLED and The Frame TVs
Where is the coaxial tv antenna tv connection on Qled 77" tv?
Samsung_Moderator
Hello @Members_PMetu8z! Thank you for reaching out! As your TV does not have this option you will need to purchase a 3rd party device that will convert the signal into HDMI.
Not_MYFOR
Should be behind the TV next to the hdmi
Or if your model include a box
Then the ANT should on tv it self
But makes sure the box is connected
Members_PMetu8z
No box..handy man who installed told me forget it they no longe have coaxial connections on expensive tvs...I stream everything but like antenna connection for when internet is down. TV on the wall now so can't see if they told me wrong info YGGH
Invid
Check out Tablo. It's a one time hardware fee, connect the tablo to your home network, you connect the antennae directly to it, and stream it to any TV via an app on your TV.
Samsung_Moderator
