Remote - solid red light. Burning through batteries
(Topic created: 03-03-2025 06:33 PM)
Jbjanice
QLED and The Frame TVs
Our Frame Tv remote has a constant solid red light.  We changed batteries, and it works but realizing it’s burning through the battery life.  Any suggestions?
Samsung_Moderator
Hello! Thank you for reaching out! You may need to purchase a new remote. Please go to samsungparts.com to purchase a new remote.
Tidbitty
Black Hole
By chance some type of liquid was spilt on it?
RobXbalboa
Red Giant
Sounds like a button is stuck
rfdkxdd
Cosmic Ray
You could also try getting a new remote if there are not to expensive. I don't know though because I have not gone shopping for remotes
Samsung_Moderator
