One remote power set top cable box
(Topic created: 03-01-2025 11:34 AM)
blueman1030
QLED and The Frame TVs
The Samsung One Remote controls the Samsung SMT-H3362 cable box for guide, channel selection etc. But the remote will not turn on/off the cabox box's power. Is the cable box too old for such a function, or is there a setting that allows it to be controlled?
Samsung_Moderator
Hello! Thank you for reaching out! Is the cable box connected to the CEC port? Also have you made sure to turn on anynet+ on the TV, you can do that by using the following link: https://www.samsung.com/us/support/answer/ANS00077511/
1 Reply
Samsung_Moderator
