Solar remote red light stays on continuously
(Topic created: 04-28-2024 04:09 AM)
Sathish1
QLED and The Frame TVs
My remote is not working and red light stays on continuously.
Samsung_Moderator
Thank you so much for confirming that. I have a couple links that may be helpful with this. The first is our general troubleshooting guide for remote control issues. The second is a guide more specifically about if the solar remote will not charge.
1. Remote Control Issues:
https://www.samsung.com/us/support/troubleshooting/TSG01202543/
2. Solar Remote Not Charging:
https://us.community.samsung.com/t5/Other-Mobile-Devices/Solar-Remote-Charging-Issues/td-p/2713056
Please let us know if these help!
ButtaBean_420
Neutron Star
I have the same problem and the remote doesn't work I tried all fixes no change I'm guessing it is dead
Have you tried plugging it into a charger?
ButtaBean_420
Neutron Star
Yes also tried to recalibrate but nothing red light stays on no flashing and no buttons will work
Samsung_Moderator
Hello! Thank you so much for posting about this. I completely understand your concerns about the remote not working and the red light flashing. I'll be more than delighted to assist. Are you in a room void of sunlight? If so, it could not be getting enough charge.
ButtaBean_420
Neutron Star
The red light doesn't flash as me and OP both stated the light stays on all the time and doesn't work
Samsung_Moderator
Who_bhaskartripathi
I am not sure why but I also have the same problem, did they push any software which caused this issue???
