Solved problem connection between sony WF and WH headphones and samsung TVs
(Topic created: 3 weeks ago)
pfeijao
QLED and The Frame TVs
I found the solution for this problem with audio using bluetooth connection to Samsung TVs:
(Its connects corretly via bluetooth but no sound on the headphones)
in order for the problem of connection between sony WF or WH Headphones to Samsung TVs you have to go to:
1)Go to Options menu on your TV
2) go to menu Sound
3) go to Expert Settings
4) go to Digital Output Audio Format : Choose PCM.
!!Thats it! Problem solved for good!
The problem is that if Audio format is AUTO sony headphones cannot connect correctly. If you put PCM all is done perfectly.
