- Mute
12-09-2022 09:45 AM (Last edited 04-09-2023 05:49 AM ) in
QLED and The FrameHi, for around a week now, I can no longer pair my Bluetooth headset Sony wh-1000xm4 with my Samsung TV Q70A. I was using the headset nearly daily even though it was not perfect, it was working.
Now, each time I try to pair with the TV, I select the device, and it starts the pairing process just when I think it is working; the pairing crash on the Sony and the device is no longer paired.
STR:
- Open the TV, go to SmartThing's quick menu, and I can see wh-1000xm4
- I hold the pairing button on the Sony until I hear 'bluetooth paring'
- On TV (SmartThing's quick menu), I select the wh-1000xm4
- I see the TV writing connecting, then connected
- In the Sony headset, I hear 'Bluetooth pair....'. and then crash
- The crash seems to be the voice staled at the end of the word paring saying 'ingggggggggggg'
The sony works well on other devices like computers (windows, mac) or bose speakers and phones (android, iPhone), so I guess something changes on the TV.
Please, I know SmartThing is a different department, but please be smart and forward it internally not to make me waste my time
I have found a workaround, it is not working 100% of the time but often:
- Hold the power button of the TV remote so it close and also restart while still pressing the button
- Pair the headset right away
- Open Netflix after
- I was able to pair it 3 times yet this way.
Second workaround (faster than the first, credit to @TargetPriority there
- Go to setting > General > Accessibility > multi audio output
- Click on Multi-output Audio if nothing is appearing
- Select you bluetooth device then click connect
- Audio work in the bluetooth device
Note: The only disadvantage is that you can't use the TV remote for the headphones' volume control
Thansk also to @vustinas that shared it even before but did not saw it!
In conclusion, if you also encounter the problem, please escalate it to Samsung support; the more users report it, the more it will get attention!!!!
@samsung By counting US & CA post, we have around 40 persons reporting this issue, can we have any help on this? Or any statement or update?
Reported Sony model related to this problem:
- WH-1000XM5
- WH-1000xm4
- WH-XB910N
WF-1000XM4(Fixed with Sony firmware update (v2.0.0)- WH-CH720N
Other TV model affected:
- AU800055
- AU9000
- QE55Q60AAUXXH
- q800
- 55Q80A
- QE55Q80AATXXH
- 90AA85
- QN65Q80
- QN75
- QN900A
- QE65QN90AATXXH
- QN94aa
Last update (Feb 3): Sorry guys, I spoke with support 4-5 times, always the same result, they escalated to a higer team said I will have response after 5 days and I'm left to hangup on waiting for replies. Samsung, I lost faith in you, if only you would let my effort knows it is taking into fixing the problem I would consider contnuing buying your product, now I start feeling you are not worth it. This is the last time I put effort enhancing Samsung experience.
BTW, support is making a joke of redirect me to a clear your cookie image when I tried to push for more information. This is a disgrace!!
Solved! Go to Solution.
- Mute
04-09-2023 05:45 AM in
QLED and The FrameI imagine this problem will get more attention soon since there is this an article out there stating it clearly.
- Mute
12-12-2022 12:15 AM in
QLED and The FrameSame here, just started recently too. Perhaps some sort of recent upgrade is causing it?
- Mute
01-06-2023 12:39 AM (Last edited 01-06-2023 12:42 AM ) in
QLED and The FrameSame here. Not buying Samsung anymore.
@samsung, I literally can't use my ($2000) TV anymore. It's mounted and too loud for my apartment neighbor at night. I work during the day. I have one nice pair of bluetooth headphones, the Sony WH-1000XM4's. If I can't use them with your TV, I can't use your TV. I'm not spending another $X00 just to get a pair of headphones that work with your TV. And if I can't use your TV because you won't fix this, I'm never buying Samsung again.
Fix this. It's your problem, not Sony's. The headphones have never failed with 20+ other products; your TV has now failed with 1/3 of the products I've connected to it.
How do we escalate?
- Mute
01-09-2023 11:21 AM (Last edited 01-09-2023 11:23 AM ) in
QLED and The FrameTo escalate, you can go to samsung.com or samsung.ca and use the chat on the bottom right. You can also search on google for Samsung support. During the call or chat, ask to escalate to the developer, so they fix it.
- Mute
12-13-2022 05:33 AM (Last edited 12-22-2022 06:38 AM ) in
QLED and The FrameI suspect the firmware 2111.1 does so. I escalated to their support team, they said I would get an answer in around 3 days...
Update: I request an update again and still waiting for their response.
- Mute
12-14-2022 03:41 PM in
QLED and The Frame- Mark as New
- Mute
12-22-2022 06:40 AM (Last edited 12-22-2022 06:42 AM ) in
QLED and The FrameFYI, I had time-to-time distortion with the Sony headset in the past but rarely. Now it is more of a pairing crash that is always there unless I use my workaround steps below. However, I would not be surprised that the firmware had more side effects and it is affecting your Bose like you are seeing
- Mute
12-14-2022 05:24 PM in
- Mute
12-13-2022 09:31 AM (Last edited 12-14-2022 06:05 PM ) in
QLED and The FrameFor anyone having the trouble I seem to have found some workaround:
Update: workaround not always 100% working but better than never working!
- Mute
12-13-2022 11:40 AM in
QLED and The FrameI have the same issue, right after my Sony mx4 would not connect anymore I got the message: firmware update done... I already feared a crappy update from Samsung 😞
Additionally my software update option is greyed out now ... I hope I can update to a newer version that fixes this
