userSrAtDbFIXO
- Mute
07-25-2021
07:40 PM
(Last edited
07-26-2021
08:48 AM
by
SamsungRei
) in
How do I link my tablet with my phone please can I use my tablet to send texts and make calls
Solved! Go to Solution.
LynniePie
- Mute
07-25-2021 09:15 PM in
Tablets
Pull down the notification box, swipe it down again so to see the quick panel buttons. Look for the button that says "call and txt on other devices" and click it. If you don't see that button, click the three dots in the upper right hand corner and choose edit buttons. You may have to add it in your quick panel.
LynniePie
- Mute
Tablets
userSrAtDbFIXO
- Mute
07-26-2021 05:50 AM in
Tablets
LynniePie thanks so much appreciate it I got it 👍thanks
