Replacement S Pen not connecting for air actions!
(Topic created: 02-11-2024 01:35 PM)
Tablets
Hey, i need help trying to get this replacement S Pen connected to my base model Galaxy Tab S8, for some reason it won't connect for air actions despite putting it on the back where it goes to connect and charge
Any help would be appreciated! And i just got it today from amazon
Tablets
Just found out, that the one i got, doesn't have Bluetooth 1707697807982.jpg
Tablets
userZNnTdcqwZP
Supernova
Tablets
On that S pen page, tap 3 dots at the upper right >> Reset S Pen. Then it will show you to place the Spen on the back of your tablet
Tablets
Ric221
Comet
Tablets
I'm glad you figured out what the problem was.
