S Pen Won't Connect to Air Actions and Have to Press Hard To Use
(Topic created: 02-10-2025 07:55 AM)
cheezytoast
Tablets
Hi, basically the title.
My S pen (official from the Samsung site) has stopped working. Yesterday it was fine, today it's not. It won't connect to Air Actions and to do anything on the screen, I have to press hard. I've done everything recommended. I took it out and out to back in the right position, took the tablet out the case and wiped down the charging spot, turned off Air Actions and reset the tablet, kept Air Actions on and reset the tablet, reset the tablet with the pen attached, reset the tablet with the pen detached, and reset the pen in settings and nothing has worked. I tried charging it for an hour with Air Actions off, not touching it at all and it showed no improvement. Is it completely gone or can I save it?
It's the Galaxy Tab S9/S9+/S9 Ultra S Pen, Black.
Tablet is the Galaxy Tab S8+
bill-e
Cosmic Samsung Care Ambassador
Tablets
I know you said that yoou reset the tablet but did you try resetting the S-Pen by clicking on the 3 dot menu?
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
LongHiker
Galactic Samsung Care Ambassador
Tablets
@cheezytoast When you charged the S Pen, did you see it actually charging? or no indication of charging?
cheezytoast
Tablets
The s pen picture would appear at the top of the screen with a lightning bolt under it so I assumed it was, I can't see battery status or if it's charging in seettings.
LongHiker
Tablets
@cheezytoast If you go into tablet settings -> Advanced features -> S Pen it should show you a picture of the pen. Just above and to the right it will show "Ready" or the battery percentage if the  S Pen is not attached to the Tablet.
cheezytoast
Tablets
I don't have anything but the picture of the pen on my screen, maybe because it's not connected to Air Actions?
liyah21
Tablets
Did anyone find a fix? I have a s23 ultra and having the same issue and its not even charging
bill-e
Tablets
Bill
