Can't connect Washer and Dryer to Wifi /Smart Things
(Topic created: 02-10-2025 01:52 PM)
mjolnier
Washers and Dryers
I have an older set of Samsung Washer & Dryers, but they should still connect to the 2.4GHz network. They are in the same room as the Google Nest Wifi Pro (they don't allow you to turn off a specific frequency, unfortunately, it's always on 2.4 GHz, 5 GHz & 6 GHz.)
But I had an old Wifi extender, and I put that in 2.4GH only mode with a different name than my network but connected it to the Google Nest Wifi Pro to make sure I had internet access, which I did.
I did the same process to set them up. I don't have a SmartThings QR code on them so had to add them manually, by pressing the Smart Control button until AP appears. My phone does find the washer and dryer but quits at connecting to the Wifi repeater, which is plugged in directly behind them.  I recall in the past when I tried this that you could find the model number but maybe that's changed with the new app.
Any ideas would be appreciated and thank you.
Models:
Washer: WF50R8500AV/US
Dryer: DVE50R8500V/A3
mjolnier
Washers and Dryers
Also, I have a brand new Samsung Dishwasher that connected flawlessly to SmartThings before I tried this setup. So it's definitely something with the Washer/Dryer. All my other Samsung equipment is connected to the network fine.
mjolnier
Washers and Dryers
Hey, wondering if anyone at Samsung could respond to this for me. Thank you.
Samsung_Moderator
Washers and Dryers
Hey there @mjolnier! We would recommend reaching out to our SmartThings community at the following link: https://community.smartthings.com/ to get the best support.  You would be working with our Smart things team directly, and they will get you up and running.  Thank you for being a Samsung customer!
Communityuser3ir3m
Washers and Dryers
It sounds like your washer and dryer are struggling to connect to the WiFi repeater. Since your phone detects them but fails at WiFi setup, try these steps:
Reset Network Settings ā€“ Hold the Smart Control button until "AP" appears, then restart setup.
Manually Connect to AP ā€“ In your phoneā€™s WiFi settings, connect directly to the washer/dryerā€™s network before proceeding.
Ensure 2.4GHz Only ā€“ Confirm the repeater is in 2.4GHz mode only and not switching bands.
Try a Different Repeater ā€“ Some extenders may cause compatibility issues.
If issues persist, consider using a mobile hotspot for initial setup.
