Lionel1
- Mute
07-28-2024 06:31 AM (Last edited 07-28-2024 06:33 AM ) in
Washers and Dryers
2y old Samsung washer. On spinning makes insane crazy noise. As you can see in the picture it melted and part disconnected from spinner. Absolutely outrageous! Any suggestions or parts number that I need to look for? TIA
1 Reply
cpss1
- Mute
07-28-2024 07:21 AM in
Washers and Dryers
Check the drum bearings. If the bearings are going to **bleep**, the drum will wobble hitting the door. The bearings look like wheels that support the rotating drum. If you lift the entire top up, you can grab the drum and check the play.
![](/skins/images/0BE7206E67E1C4228578B9F135D24B17/responsive_peak/images/icon_anonymous_message.png)
