Dryer DV22N6800HW How to Turn On Sound
(Topic created: 09-11-2022 12:12 PM)
userBA213yIwQn
Washers and Dryers
I have a Samsung heat pump dryer. How do I turn the sounds on? I turned them off, it was accidental and I don’t know how I did it. The light next to the alarm off indicator is lit. When I hold down the “Wrinkle Prevent” button for 3 seconds - the directions given in the  book to turn the alarm off - nothing happens. Thank you!
Samsung_Moderator
Washers and Dryers
Hi there, Thanks so much for reaching out about this. You are correct, pressing and holding the "Wrinkle Prevent" button on this model should turn the end of cycle alarm on/off. If you have verified that the child lock is not engaged, and other buttons on your dryer are working, we would recommend service as the next step. There are a couple options here we can take based on your warranty status.
If you’re in the one-year manufacturer’s warranty, please gather together the full model and serial number of your unit, and have ready your name, street address, 2 phone numbers (Best contact, alternative number), email, and place of purchase. Provide this information to an agent, in one of the following options below:
1.) Reach out to a Moderator directly, by selecting our name and the message option. When messaging please use a link to this thread in addition to the info above.
2.) Reach out to us on Facebook or Twitter. Please provide the same info as above, as well as the link to your thread.
3.) You can also contact 1-800-726-7864, if you’d like to speak with a live agent about this situation.
4.) Last, if you wish to speak with a live agent and don’t want to call in, you can reach out to our Live Chat team.
If you’re out of the one-year manufacturer’s warranty:
1. You can utilize this link to locate an authorized service center in your area to obtain estimates for repairs: http://www.Samsung.com/us/support/service/location or reach out to any local repair shop.
2. The other option, would be a replacement of the unit. Samsung.com offers amazing deals on different models that may be to your liking, check out those deals here: https://www.samsung.com/us/dryers/
1 Reply
Samsung_Moderator
Washers and Dryers
