Washer and dryer noise
(Topic created: 06-14-2023 02:47 PM)
Alohakakou
Washers and Dryers
I am sure I won’t get the answer I am looking for but here goes.
I have the basic model washer and dryer it seems. It does not have the button option to turn the chime off.
My question is where is the speaker located that makes the sound or where does the sound come from?
Botsy
Washers and Dryers
Type the kind of washer dryer into the Google search and ask how to turn on/off alert sounds. I'm assuming that you hadn't tried that or looking carefully through the manual. A lot of times two buttons will have to be pressed at once or something like that.Sometimes it's jumbled in with everything and you can miss it. Google should show you video links on YouTube that can help hopefully they will. Good luck.
Washers and Dryers
Well, I'm sure it's inside of the part that the dial is on. Or the buttons, if there is no dial. If you take that part off, make sure you use a soldering iron to take the speaker off so you don't damage the board
Alohakakou
Washers and Dryers
Thank you very much. I’ll have to take a look behind there and make sure to use a soldering iron. Appreciate the time mahalo
Botsy
Washers and Dryers
