Dryer will not stop. Displaces a loop on the control panel
(Topic created: 02-24-2023 12:06 PM)
barry2
Washers and Dryers
Dryer works but it continues to run past the logical end time and displays a loop on the control panel.  No error code is provided.  Not clear what the looping indicates.  Any thoughts?
barry2
Washers and Dryers
NVM.  looks like the wrinkle prevent setting was on.  my bad
GamerTechPA
Washers and Dryers
Unplug the dryer and replug it in. The it should work
GamerTechPA
Washers and Dryers
Then*
barry2
Washers and Dryers
