Flex Washer and Dryer do not store any options and settings but My Cycles
(Topic created: 01-11-2023 09:18 AM)
userZ7NdDWGJKO
Washers and Dryers
Samsung_Moderator
Washers and Dryers
Thank you so much for providing that! I've been reviewing the features and options listed in the user manual for your model (linked below). According to page 52, this model does have the option to save cycle settings in the My Cycle section of the SmartThings app. However, features such as the drum light would need to be manually engaged each use.
https://downloadcenter.samsung.com/content/UM/202301/20230103163556421/FLEX_WV9900A-MD_SImpleUX_UM_D...
userZ7NdDWGJKO
Washers and Dryers
For example, to turn on the automatic light, I have to turn it on manually every time after turning the power on. Should I return the malfunctioning appliances back to the store?
NickSapienza
Washers and Dryers
No just turn on the automatic light setting instead.
Samsung_Moderator
Washers and Dryers
Oh no! I completely understand how annoying that can be with your settings, but I am more than happy to look into this for you!  Could you provide me with the model of the washer?  That way we can make sure that your model has the ability to save settings outside of the "My Cycle" function.
userZ7NdDWGJKO
Washers and Dryers
WV60A9900AV DVE60A9900V
Samsung_Moderator
Washers and Dryers
