- Mute
02-02-2025 07:18 AM in
Washers and DryersI read that I can set up dispenser 2 as general laundry detergent as we have 2 different types we use at the house...one for adults and one for baby clothes. However I don't know how can I turn on or turn off dispenser 1 or dispenser 2 to use only the desire dispenser. Thanks for any help or explanation to this question.
Solved! Go to Solution.
- Mute
02-07-2025 02:54 PM in
Washers and DryersYou are more than welcome. It is stated as such because you absolutely can use it as a general detergent dispenser to release during the cycle, and certain cycle even allow you to delay the detergents release from that specific dispenser as stated. The 2nd dispenser can be used to add laundry care items such as fabric softener or spot cleaners for sports or grass stains, but it cannot operate separate as referenced.
I located the manual here- chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://downloadcenter.samsung.com/content/UM/202402/20240222125354697/OID73831_IB_H700-550-500D-AD_... on starting from page. 69 is step-by-step assistance with using the 2nd dispenser.
- Mute
11:54 AM
(Last edited
02-04-2025
11:55 AM
by
SamsungStephani
Hi there, we recommend you use the user manual here- https://www.samsung.com/us/support/downloads/ for direct review using the model code to search. However, it will always be our pleasure to look into this for you as well. To proceed, can you provide me with the model code for review?
- Mute
02-04-2025 12:17 PM in
Washers and Dryers- Mark as New
- Mute
02-06-2025 02:41 PM in
Washers and DryersYes, that is correct the on/off function is available and in fact, the manual states you can set this dispenser to dispense detergent (General or Specialty) or softener however it does not offer separate options as mentioned. The hub does offer great additional features, and we definitely understand the mentioned options is not available at the moment, however so many more are. We encourage you find what fits your household needs and enjoy your new hub.
- Mute
02-06-2025 02:54 PM in
- Mute
