Top load washer won't stop filling with water
(Topic created: 07-11-2023 09:42 PM)
user8at7qiHEdl
Washers and Dryers
The water of out of rinse spout sometimes won't shut off even with power off and sometimes it does shut off. It's a hit or miss...help please
Thanks in advance
user8at7qiHEdl
Washers and Dryers
I replace the water valve in the control...bought on Amazon for $35 and took about 30 -40 minutes to take apart and replace. As of now it has been fixed Screenshot_20230727_142453_Amazon Shopping.jpg20230726_175232_1000003705_1690408357.jpg
Jeff49
Washers and Dryers
I have a similar problem. Water won't stop filling--though it will stop when I hit pause or End. The tech just replaced the water level sensor, but that did not fix the issue. He's still trying to figure it out.
user8at7qiHEdl
Washers and Dryers
Jeff49
Washers and Dryers
Update -- he did get it fixed in the end, with the replacement of the water-level pressure switch. It was a finicky repair, and I hope it holds!
