- Mute
08-25-2021 08:36 PM in
ComputersI have this 13inch one for little over 2 months. I just noticed that my laptop gets really hot and a fan rarely kicks in. It is too hot to touch it with a finger for more than a couple of seconds. Also, it appears that once a laptop gets hot (it only takes a couple of minutes after starting it and doing stuff), a noise comes out off from the bottom of the computers. It a period buzzer sound in about every 4 seconds. It is audible when I am in the quite room and it continues until a power really cuts off while a comp is getting turned off. If I turn on a laptop again in a few minutes (before it really got cooled down), it starts right away during a booting process. Anyone has a similar issue? Probably a defective fan?
Solved! Go to Solution.
![Samsung Moderator Samsung Moderator](/i/rank_icons/moderator.gif)
- Mute
08-26-2021 05:17 AM in
ComputersI can definitely understand your concern here. Let's try to alleviate some of the stress by trying this link: https://www.samsung.com/us/support/troubleshooting/TSG01109648/ If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
- Mute
![](/skins/images/AED0E0FA43E79A76750005D5146B54BA/responsive_peak/images/icon_anonymous_message.png)
