samsung galaxy notebook pro does not turn on when power is applied (when the lid is closed)
(Topic created: 04-11-2023 01:27 PM)
Trantor777
Computers
samsung galaxy notebook pro does not turn on when power is applied, when the lid is closed
this is very inconvenient in the scenario of working on large monitors through the hub
macbook can do this out of the box
lenovo generally has a corresponding trigger in the bios, enable or not when power is applied
Is it really so difficult to make an appropriate function like lenovo for example?
Samsung_Moderator
Computers
Hello! Thank you for reaching out! This is a really handy feature to be able to have the laptop lid closed and still be able to work the laptop. You can try the following link to see if this will work for you: https://www.samsung.com/us/support/answer/ANS00083427/. This feature is not available for every model of laptop.
1 Reply
Samsung_Moderator
Computers
