Flip 6 – Inner screen freezing and charging port not working
(Topic created: 09-11-2024 08:43 AM)
cfr805
Cosmic Ray
Fold & Flip Phones
Hey everyone,
I wanted to share a frustrating experience with my Samsung Flip 6 in case anyone else is facing similar issues, and maybe get some advice.
I’ve only had my Flip 6 for about a month, but after a recent update last week, the phone completely stopped charging via the port, whether it’s open or closed. I contacted Samsung, and they wanted me to drive 40 miles to get it looked at, but that wasn't practical for me, especially since I can’t be without my phone for an extended period of time. Luckily, it still charges wirelessly, and I was able to resolve this issue by filing a warranty claim with AT&T. They’re sending me a new phone, which gave me some hope that maybe I just had a bad unit.
However, today at the gym, I opened my phone only to find that the main screen is completely unresponsive—frozen solid. No matter what I do, it won't respond to touch. I’ve tried restarting it several times, turning it off and on, different charging cables, different plugs, everything... and nothing works. Now, I can only use the front screen for basic tasks since it’s the only thing that still works.
At this point, my confidence in the Flip 6 is pretty much gone. I’m still waiting for the warranty replacement, but now I’m seriously wondering if the new phone will have the same issues or if I just got a lemon. Has anyone else had similar problems? Is there something I’m missing? I’ve exhausted all my options, and I really don’t want to lose faith in this phone, but it’s been a rough experience so far.
Samsung, if you're listening, please help. This has been incredibly frustrating!
Thanks in advance for any advice or help.
Samsung_Moderator
Fold & Flip Phones
Hello, Welcome, and thank you for being part of the Community. We understand how frustrating it is for the charging port to quit working and for the inner display to freeze.
Have you run the diagnostics in the Members app? In the app, select the Support tab>Phone Diagnostics
You can also try testing the phone in Safe Mode: https://www.samsung.com/us/support/answer/ANS10003495/
For the charging port not working, you can try the steps here: https://www.samsung.com/ph/support/mobile-devices/what-to-do-if-your-galaxy-phone-is-not-charging/
For the screen freezing, you can try the steps here: https://www.samsung.com/us/support/troubleshoot/TSG10001440/
We also recommend submitting an error report in the Members app: https://www.samsung.com/ae/support/mobile-devices/raising-an-error-report-via-samsung-members-app/
If you are still unable to wire-charge the phone and/or the screen continues freezing, it is recommended to have the phone evaluated by an authorized technician. You can use the following link to find a list of service centers in the U.S. that can do the evaluation: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For assistance outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
LongHiker
Galactic Samsung Care Ambassador
Fold & Flip Phones
@cfr805 Sorry that you are having this issue. I am not seeing this with my Flip 6.
cfr805
Cosmic Ray
Fold & Flip Phones
Update:  After doing the 7 second reset by holding the power button and volume down keys, the screen itself regained touch sensitivity and I am able to use the main screen again HOWEVER, the charging slot still does not work.
Klarp
Cosmic Ray
Fold & Flip Phones
Did you ever drop it and it fell on its hinge? I heard a case w.o a hinge proctor would make the screen unresponsive. After the update i don't have any issues with my z flip 6
cfr805
Cosmic Ray
Fold & Flip Phones
No, the phone hasn't been dropped.  I credit this to the little ring on the Samsung case that I bought when I made the initial purchase.  The screen is now working again after the 7 second reset.  The charging port is still out.  I think I got  lemon.
Robin621k
Honored Contributor
Fold & Flip Phones
Try this, go to settings, apps, next to where it says your apps there is 4 lines and an arrow pointing down, tap on that and toggle on show system apps, press OK, type in the search box usb settings, tap on that, go to storage and clear cache.
I hope this helps
cfr805
Cosmic Ray
Fold & Flip Phones
Did the above, still no charge.
cfr805
Cosmic Ray
Fold & Flip Phones
And now again!!!! The screen froze again.  The 7 second reset no longer fixing the issue.  I give up....
cfr805
Cosmic Ray
Fold & Flip Phones
So back to square 1:  Main screen frozen - Will not respond (small screen still works...thank god.
2.  Charging port does not work - Wireless still works however.
New phone on the way from ATT but confidence is down.
If you have any ideas they have to be done through the front screen...
naikvivek
Fold & Flip Phones
My Samsung Flip 6 has the same issue and contacted Samsung and had to take appointment with Asurion as authorized repairer. My experience with Asurion been bad.
Wish me luck!
