- Mute
08-29-2022 04:00 AM in
Galaxy BudsSolved! Go to Solution.
- Mute
09-16-2022 06:43 AM in
Galaxy BudsNevermind I figured out a solution. Go to your settings and reset the device. Should work fine after that.
- Mute
09-15-2022 09:24 AM in
Galaxy BudsSame issue here, and same ear. Right ear works fine for increasing the volume... the left ear has stopped responding
- Mute
09-16-2022 06:36 AM in
Galaxy Buds- You two are not alone. Same issue. I'm sure others are also having the same problem. I'm going to bring the issue up to customer support.
- Mute
- Mute
10-17-2022 05:19 PM in
Galaxy Buds
