Buds Pro 2 Ambient Sound Volume Level Slider
(Topic created: 09-18-2022 10:19 AM)
Hosmitch
Galaxy Buds
Hi,
This was a feature I really like with my Bud2. I don't see it with the Buds Pro 2. Any workaround or know if they will add this feature later?
Hosmitch
Galaxy Buds
Thanks. That could be it. I've been told of a way of getting the feature but it is through the Accessibility settings. So it's not the exact same and seems to be geared for those with hearing issues, but I'm still Playground with the settings.
Steps:
Earbud Settings
Accessibility
Turn on both Noise controls with one ear bud and Amplify Ambient Sound.
When you return to the main page and select Ambient Sound a new selection option appears to adjust the Ambient settings.
Jess04
Comet
Galaxy Buds
They may have removed it since the Buds 2Pro are supposed to block up to 40% more background noise. Making that slider obsolete.
Hosmitch
Galaxy Buds
Steps:
Earbud Settings
Accessibility
Ellin
Sun
Galaxy Buds
Follow those steps above, they work
