- Mute
08-28-2019 04:44 AM in
Galaxy Note PhonesMy note 10+ does not recoginize the USB C Audio Jack.
Solved! Go to Solution.
- Mute
09-05-2019 08:51 AM in
Galaxy Note PhonesI have the same problem also. i bought 2 kind of adapter and they didn't work
- Mute
09-16-2019 08:52 AM in
Galaxy Note PhonesThis works sometimes. Try pulling down your notifications go all the way to the bottom to connected USB. Should be on the bottom of notifications if it's showing, try switching the controller to phone it should say it fails, then switch it back to controlled by usb. That's my fix. Even is you buy the adapter made by Samsung this still happens. Samsung fix this, ty.
- Mute
09-05-2019 09:43 AM in
Galaxy Note PhonesHere is a link to the recommended USB-C Headphone Jack Adapter: https://www.samsung.com/us/mobile/mobile-accessories/phones/usb-c-headphone-jack-adapter-ee-uc10juwe...
Samsung does not recommend the use of a splitter with the phone, due to this Samsung does not manufacture the splitters.
- Mute
09-18-2019 07:18 PM in
Galaxy Note PhonesI ordered a cheap one off amazon. To my amazement it didnt work. I'm using this for my cars outdated stereo system. I then plug in headphones with an aux and they worked. Bewildered, I then unplug just the aux from the headphones and plug the aux from my car into it. Viola, music.
- Mute
10-21-2019 10:52 AM in
Galaxy Note PhonesThis worked for me as well
- Mute
12-06-2019 04:42 AM in
Galaxy Note PhonesI do the same. I'm a technician & use to plug my S7 into the aux port for hands free calling. Now with my Note 10+ (using the dongle) I get music, but callers can not hear me if I try using for hands-free calling. So frustrating!
- Mute
12-19-2019 04:07 PM in
Galaxy Note PhonesSame here but it works only once and then have to reset again with headphones
