Note 10 USB C 3.5 mm Adapter Type C Audio Jack
(Topic created: 08-28-2019 04:44 AM)
user2GDBxaTfuP
Cosmic Ray
Galaxy Note Phones
My note 10+ does not recoginize the USB C Audio Jack.
JUMP TO SOLUTION
userYnFRtk8fsX
Galaxy Note Phones
So what about when it happens with Samsung's adapter?
SamsungAdam
Galaxy Note Phones
@userYnFRtk8fsX I would be happy to assist you further. Can I please have the model number for your Audio adapter?
Be sure to click " āœ“ Accept as Solution" when you find an answer that works for you.
users8ok0etVmH
Galaxy Note Phones
This isn't a  solution,  this is you telling us to buy your product, Wish I had done a little more  reading  on this phone,  knowing that  you're building  a wall around your  product  like apple has, I wouldn't have  bought it. This is the last phone I buy of yours.
userhKeXuYe8tV
Galaxy Note Phones
I thought I was having an issue with my headphones plugged in via the USB C port.
I am using an official Samsung USB C to 3.5 jack, and have a Samsung Note 10 plus 5G
Without the jack the phone played sound through the speakers, then I plugged the jack in and there was no sound. I assumed the connection was not working for some reason.
Eventually I found the volume was set to zero when the headphones were plugged in, even though the sound was loud enough using the phone's speakers.
So if the volumn control on the side of the phone is set to say half way for the phone's speakers, does not mean the volume is half way for the headphones when you plug them in, they work separate. The phone senses when the jack is plugged in, you can see this in the notifications.
userC7XUxNydLC
Galaxy Note Phones
Does this adaptor work for external microphone in as well?
Thank you,
Rich
userGZJ4plNnqs
Galaxy Note Phones
my note 10 says usb device not compatible with the Samsung recommended adapter.   šŸ˜ž
monkeytheboy
Galaxy Note Phones
Samsung is right. The connected USB device is not supportive of profit making. Even though USB devices are universal, and that the Note 10 has an internal DAC, we still do not support anything that does not make money. Thanks for understanding.
šŸ¤‘:dollar_banknote::money_bag:
ImamAli7
Galaxy Note Phones
Today i got a message from Samsung Finland Come get your order USB-C to aux adapter from Samsung USA. and i was first one who ordered from samsung official store and tried it today and still not working !! I tried almost all of the usbc aux wires only apple's works but with low volume. The problem isn't in wasting money but it's too annoying samsung's usbc aux doesn't work on my Samsung Note10+ phone. Whats the solution.
Leinz
Comet
Galaxy Note Phones
The N10 acknowledges certain adapters. It doesn't seem to care for ones devoid of their own DAC. That's why only 1 of 2 that I own work. I ended up using a Type C external DAC/adapter originally bought for audio work on my laptop; it does up to 384/32bit (Windows).
I haven't had a chance to purchase Samsung's headphone adapter, but many others have seen success using the US Note10 (Snapdragon).
If my reply has aided your issue please consider liking it. If the problem is solved you may pick it as a solution.
churf
Galaxy Note Phones
After 2 failed purchases from Amazon, I got the Google branded USB-C to 3.5mm adapter from Best Buy and it works perfectly.
