My phone audio sound cuts in and out
(Topic created: 11-03-2024 08:47 AM)
TyBae
Galaxy S Phones
Does anybody know why my Auto goes in and out? It will play for 10 seconds then cut out ??
TyBae
Galaxy S Phones
Thank yall I will contact the carrier and see if they could send me a new phone this so unacceptable and I just brought this phone like two weeks ago crazy but thanks again.❤
CasualMember
Comet
Galaxy S Phones
Your notification sound might be short.
TyBae
Galaxy S Phones
Is it a way I can fix it ? I factory reset my set phone still doing the same thing
MrGhoul
Sun
Galaxy S Phones
If you did a factory reset and the issue is still there, it might be a problem with the device itself. I would take your phone to your carrier first and see if they could help. Or you might have to have it repaired.
TyBae
Galaxy S Phones
