Issue with voicemail and incoming calls
(Topic created: 06-23-2021 01:20 PM)
Ryan376
Galaxy S21
I recently switched from an iphone to a galaxy S21, and was having trouble accessing my voicemail. I installed the AT&T visual voicemail app, which let me veiw my voicemails, but now when someone calls me I no longer have the option to answer them. It just goes to voicemail. I did not change any of my settings when I installed the app, and deleting it did not fix the issue. What is a good way to fix this?
SamsungRei
Galaxy S21
I know how frustrating this must be. This article provides some information on why this may occur and some tips on how to correct it. https://www.businessinsider.com/why-does-my-android-go-straight-to-voicemail If the call continues to go straight to voicemail after following the steps in the article, you will need to reach out to your service provider for additional troubleshooting. I apologize for the inconvenience.
1 Reply
SamsungRei
Galaxy S21
