Help with a wireless charging routine
(Topic created: 01-17-2023 03:09 PM)
Galaxy S22
Can someone help me with a routine I am trying to make for my S22 Ultra, I want to set a routine that has something to do with wireless charging and I want to turn off fast wireless charging at a specific time, and put a do not disturb schedule for it as well, If I can get some assistance with that, that will be very helpful, please and thank you, currently getting a wireless charging stand today and need to have a wireless charging schedule for it, I am not to familiar with Bixy Routines, it would be helpful and much easier to walk step by step
LongHiker
Galactic Samsung Care Ambassador
Galaxy S22
@LugiaDaryl27 Here you go:
  1. Open settings
  2. Click on Modes and Routines
  3. Click on Routines in lower right
  4. Click the + button in upper right
  5. Below the If, click the "+ Add what will trigger this routine"
  6. Click Time period
  7. Set your desired start time and end time. Also pick the day (or days) that you want this routine to execute on.
  8. Click Done
  9. Below the Then, click the "+ Add what this routine will do"
  10. In the search field, type in "Fast"
  11. Click on Fast wireless charging
  12. Click Off, and then Done
  13. Just below that entry, click on "+ Add action"
  14. In the search field, type in "Disturb"
  15. Click on Do not disturb
  16. Click Off, and then Done
  17. Now click Save
LongHiker
Galaxy S22
  1. Open settings
  8. Click Done
  17. Now click Save
Oxford
Honored Contributor
Galaxy S22
Why not just use the "Protect Battery" in the battery section of device care that limits battery to an 85% charge?
Galaxy S22
Because I want my phone to be at 100% charged when I am ready to hit the doors in the morning
