Low sound on calls
(Topic created: 01-11-2023 07:43 AM)
Yamialex224
Honored Contributor
Galaxy S22
Does any one a problem with the sound being low in calls and it's hard to hear outside
Samsung_Moderator
Galaxy S22
Hey there! I can certainly understand how frustrating it is when your device isn't working as it was designed. I have some steps that may help us with the volume in your calls!
First, let's try a few troubleshooting steps from this link that may can help with your volume concerns.
https://www.samsung.com/uk/support/mobile-devices/what-to-do-if-the-sound-on-your-galaxy-smartphone-....
Also, here is another link with steps on how to turn on the hearing enhancement features that may also help.
https://www.samsung.com/us/support/answer/ANS00085522/
If you're still experiencing low volume on your phone calls try these steps.
Go to settings > sounds and vibrations > volume
press the three little dots in the right hand corner
media volume limit > toggle to on set your custom volume ​
If you need any additional assistance or suggestions please reach out to us by private message and we will be more than happy to assist.
420jester
Galaxy S22
Sound beautifier app especially for earbuds otherwise the sound is rhe way to go
Yamialex224
Honored Contributor
Galaxy S22
I'm talking like on phone calls
notforhire
Black Hole
Galaxy S22
I'm hard of hearing, so I only talk on the phone with ear buds (Buds Live) or on speaker. I can't hold the phone to my ear and hear.
Samsung_Moderator
Galaxy S22
