Battery draining fast S23 Ultra
(Topic created: 02-16-2023 03:04 PM)
hiiii
Galaxy S23
I been noticing that my battery is draining quick while having it on power saving mode, with the Bluetooth off and lowest frame rate, resolution. Anyone else noticed this?
SamsungRei
Galaxy S23
Hello, We understand the concern of the battery draining quickly.
Some things that can help with Battery optimization, if you're just having a battery draining issue, is the following:
Note: The battery adaptive feature may cause the battery to drain a little faster at first until the phone adapts to your usage, and learns how you're operating, the charge will be stored and used in different manners based on how you use your phone. This sometimes can take a few weeks for it to learn the habits and customize itself to make sure you have the best performance and lasting battery.
Optimize Apps:https://www.samsung.com/us/support/galaxy-battery/optimization/
If you're receiving an overheating message check out the following link:
https://www.samsung.com/us/support/answer/ANS00076952/
If you've tried troubleshooting above, when it comes to problems overheating or exorbitant drain to the battery, repairs would be recommended. You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For international customers, please use this link: https://www.samsung.com/us/common/visitlocationsite.html
mstleldm
Galaxy S23
Yes, my S23 Ultra battery % is dropping very fast, with little input.
hiiii
Galaxy S23
I had the s20 ultra and noticed that the battery on that phone with high resolution and only power saving move on lasted more than this new s23 U
Galaxy S23
Galaxy S23
This morning. Keeps improving Screenshot_20230217_092216_Device care_1000000617_1676643736.jpg
hiiii
Galaxy S23
So no problems for you I see that's good man. Mine seems to be draining a bit quickly
Galaxy S23
Double check your background apps running and watch some battery improvement videos that helped on previous s22 ultras. Should be able to see in settings what's eating away the most at your battery too
hiiii
Galaxy S23
Kool I will check thanks
RedPanda889
Cosmic Ray
Galaxy S23
I am literally having the same issue and it is the Google messages app draining the the phone consistently in the background even when I'm not using it it's my highest use app just sitting in idle state and I don't know what to do to fix it I reset the play services for a bit that seem to have fixed it but then it went back to draining again.Screenshot_20230219_215126_Device care.jpg
hiiii
Galaxy S23
Oh wow yeah that's interesting I also have the goggle messages app I'm going to remove the app and see what happens
