S24 ultra heating and battery draining fast even on light usage
(Topic created: 01-29-2024 05:29 PM)
AP900
Halo
Galaxy S24
I got s24 ultra recently and phone is heating up and battery draining faster than expected. Please provide fix for it..
JUMP TO SOLUTION
oneuiuggg
Galaxy S24
Yes please call Samsung tech support so they know about the issue. Tech support is 24/7 call late at night they are less busy.
MarcellaZee
Galaxy S24
Anyone else's phone getting extremely hot? When I was using smart things to transfer, the phone got really hot. I thought it would be done afterwards but even now after using the phone regularly scrolling through apps it's still hot.
userLAjuAhfyfh
Galaxy S24
I've noticed that, too. I changed the power settings on my phone. It's much cooler now.
Imabhishekreddy
Galaxy S24
What did you do?
user2EmWFAU6Do
Cosmic Ray
Galaxy S24
Same here. Even scrolling on Facebook gets the area to the right of the camera extremely hot
Jtwizzle
Cosmic Ray
Galaxy S24
My s22u got quite warm and so does this. The bigger vapor chamber must be working well at removing that heat.
Mellotola
Galaxy S24
True
U22blk23
Cosmic Ray
Galaxy S24
Check to see if battery settings are set to optimized...
Not applicable
Galaxy S24
I'm having same problem, battery is draining faster than usual.. and even on slight to moderate usage phone does get heats up
Pixelator4
Galaxy S24
Experiencing the same issue! Please fix this
