- Mute
‎01-29-2024 05:29 PM in
Galaxy S24Solved! Go to Solution.
- « Previous
- Next »
- Mute
‎02-13-2024 05:00 AM in
Galaxy S24I do hope this helped!
- Mute
‎02-13-2024 05:22 AM in
Galaxy S24- Mark as New
- Mute
‎02-13-2024 05:12 AM in
- Mute
‎02-13-2024 05:21 AM in
- Mute
‎02-13-2024 05:30 AM (Last edited ‎02-13-2024 05:31 AM ) in
- Mute
‎02-13-2024 08:48 AM in
Galaxy S24Dear Samsung Users,
Is it normal for the 45W adapter to get very slightly warm when charging the phone? Also, my phone gets very slightly warm too. I am using the samsung 45W adapter that includes 5A cable.
Note: I don’t use the phone while charging. I turned off the wifi/mobile data and exit all the apps.
Another concern:
When I tried to plug in the adapter to the socket, the silver tip from the adapter sparked. There was a trace of a black substance, so I wiped it with a cloth, and it disappeared. However, upon closer inspection, there is still a slight trace on the silver tip. Does that affect the health of the battery of the phone? Could that be the reason why my adapter gets slightly warm when charging, and the same for the phone?
- Mute
‎02-13-2024 09:56 AM in
- Mute
‎02-13-2024 10:09 AM in
- Mute
‎02-17-2024 03:36 AM in
Galaxy S24My phone gets really hot when I'm using 45w charger then i bought samsung charger 25w but it gets warm as well on that. Also when I'm on video call phone gets warm upto 100F temperature and its feels really warm in hand. I haven't tried gaming yet I know it will get hot.
- Mute
‎02-20-2024 07:13 AM (Last edited ‎02-20-2024 07:16 AM ) in
Galaxy S24Hello, I'm sorry to hear about the trouble. Regarding the battery life, if you just recently purchased the phone, this is completely normal for the battery to drain a little faster than normal while in use for the first couple of days once the adaptive battery learns your usage pattern, you'll notice that the charge will last a longer. Keep using your device in the meantime, so that it will learn your usage patterns. Something to keep in mind too, when there's a big update, it may reset the learning patterns, that's why some may experience this after updates. If it doesn't get better within a few days it may be an application that's causing the drain, Check out this link; https://www.samsung.com/us/support/troubleshooting/TSG01001388/
Regarding your device overheating, I recommend checking out the following troubleshooting steps: https://www.samsung.com/us/support/answer/ANS00076952/
If those troubleshooting steps are followed, and you still are having issues, I would recommend taking the device to a technician to perform diagnostics or a potential reflash of your software. http://www.samsung.com/us/support/service
- « Previous
- Next »
